BenUK83
Feb 17, 2022Follower
Connect to Satellite over Router
ORBI RBK752 Hi, I’m having trouble where a device will always take preference connecting to the router if available over connecting to the satellite. Even if the satellite has a stronger signal. Do...
Feb 17, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
It's up to devices to pick and choose where they connect to based on distance, device design and noise and conditionss of the system.
BenUK83 wrote:
ORBI RBK752
Hi, I’m having trouble where a device will always take preference connecting to the router if available over connecting to the satellite. Even if the satellite has a stronger signal. Does anyone know of a way how I can force the device to choose the satellite in times when it will have a better connection?
Thanks
