Leasy's avatar
Leasy
connecting a orbi satellite to anther netgear modem
hi l have a orbi rbr750 l would like to know if you can connect the satellite to another netgear modem and how to do this can someone help with this please
  • FURRYe38's avatar
    Orbi satellites only connect to Orbi routers. Nothing else.
    • Leasy's avatar
      Leasy
      Thanks for answering my question not what l wanted but l have to work something else out then
      • FURRYe38's avatar
        NGs EX and EAX series wifi extenders are compatible with branded and non branded NG wifi routers.
    • Leasy's avatar
      Leasy
      yes thats right l am not explaining well
      my sats are used wirelessly at the moment but can l hard wire them which would go back to the modem then l would wirelessly connect to them with the tvs phone sonos is this possible
  • What sort of Modem?  I used to use a Netgear Cable/VOIP Modem (certified for Xfinity) and had my Orbi working with that no problem.
     FWIW, the Orbi is a Router, not a Modem.  I reckon if your Modem also has a built-in Switch, you could hang all the Orbi gear, routers and sats, off it.
    Maybe provide a little more information on what you are trying to do.
    • Leasy's avatar
      Leasy
      okay l have an Orbi RBR750 an 3 satellites can l use the l am using the router hard wired and l want to know my bedrooms have ethernet ports in the wall can l use the sats wired thru the wall and then connect the tvs wirelessly
      sorry not savvy on this really
