Cholla07
Jul 26, 2022Aspirant
Devices not connecting to the satellite
Hi I'm having the same problem. I have 3 satellites. One on each level at least and all my devices are withing recommended distance to the satellite. I even have an Alexa sitting right next to a satellite upstairs and it still connects to the main router satellite downstairs. I've scoured settings and I don't' see the ability to force devices to connect to a satellite as indicated in older posts.
Firmware Version v4.6.8.2_2.1.9
Almost all other setting are default beyond primary passwords.
Version Fios internet hard lined directly to the Orbi router. There is no other router or wireless signal device diverting the traffic before it his the Orbi Main router hub. Only device is a netgear mutli-port switch for cat hard line connectivity.
FURRYe38 or any other can you help???
You have a 7 series Orbi system?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Is the RBS ethernet connected or wirelessly connected to the RBR?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- Cholla07Aspirant
RBR750 Model
Don't have Auto channel as an option for 5Ghz, set to 48.. 2.5GH set to channel 1. Adjusted the output power to 50%.
No change in results though. All devices are still connecting primarily to the main router only.
What is the distance between the router and satellite(s)?
