R2dTOO's avatar
R2dTOO
Guide
Oct 18, 2022
Ethernet Ports Not Working on RBR750 or RBS750
I have an RBR750 and 1 RBS750. The ethernet ports are not working on either device. I've rebooted both devices, and installed the latest firmware (V4.6.9.11_2.3.5). I've also test with several different network cables. I've read online that there is an option in the settings to disable the ports, but I haven't found that. Can anyone point me in the right direction?
  • CrimpOn's avatar
    CrimpOn
    There is no option to enable/disable Ethernet ports on the router or satellite.
    • CrimpOn's avatar
      CrimpOn
      Did these Ethernet ports function correctly at one time, and no longer function?
      Or, is this the first time something has been connected to them?
      What sort of device is being connected?
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last FW update along with a full power OFF of the RBR and RBS for 1 minute then back ON?
  • iyang's avatar
    iyang
    NETGEAR Expert
    Hi R2dTOO ,
    Can we know what's devices connect to RBR750/RBS750 via ethernet ?
    Does those devices get the ip address or not  ?
    Thanks.
