Milo37
Mar 16, 2026Tutor
Firmware for the RBR850 and RBS 850
Hello, What is the latest firmware for the RBR850 et RBS850 ?
Mar 17, 2026Guru - Experienced User
If you choose to update manually, be sure to update any and all RBS first then the RBR lastly.
Follow this guide if needed:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
Good Luck.
Milo37 wrote:Hello,
