donawalt's avatar
donawalt
Hero - Experienced User
Aug 15, 2020
Firmware update - 3.2.16.6
My router just updated to 3.2.16.6, there doesn't appear to be any documentation yet on what's changed. Does anyone have access to that information? Thanks!
  • This version doesn't show the devices and sats.
    I hope it is stable though.
    • donawalt's avatar
      donawalt
      AwesomeQA  what do you mean it dosn't show devices and stats? I can't see your to images, they show as yellow triangles. If you are talking about the "Attached Devices" page, I see them all there listed as before.
      • AwesomeQA's avatar
        AwesomeQA
        Apprentice
        Yes, attached devices don’t show for me.
        I did hard reset for RBR850 and sats.
  • Release notes below but see my issue if someone has an idea of how to fix.
    My firmware is v3,2,15,32. In firmware update page it show the ability of this new firmware but update all is greyed out and I can not upgrade to this new firmware. Also the satellite firmware doesn’t show correctly and it says service unreachable. I have been having to manually update both the router and satellite sine the firmwares software auto Update will not work anymore. Any suggestions.
    However it does show the change log for the new firmware:
    Release Notes:
    [Enhancements] Supports enabling or disabling the wireless 11AX mode on 2G or 5G separately.
    [Enhancements] Includes some security enhancements.
    [Enhancements] Supports the IGMP over the PPPoE WAN connection.
    [Enhancements] Supports the profile configuration to set up the ISP's VLAN/IPTV settings during installation. The following are the limited ISPs that are supported currently: France Orange;Singapore SingTel;Malaysia Unifi, Maxis.
    [Bug Fixes] Fixes some GUI related issues.
    An
    • FURRYe38's avatar
      Please respond here to your post:
      https://community.netgear.com/t5/Orbi-AX/Firmware-will-not-update-on-router-and-satellite-says-service/m-p/1961187#M6081
      Release Notes:
      An
  • I am only able to see devices under RBR750 (router) but none of devices show up under any of the two RBS750 satellites in my Orbi app (Android). My firmaware version says 3.2.16.6
