Edwardlotz
Aug 16, 2020Guide
Firmware will not update on router and satellite says service unreachable
I hAve Orbi ax6000 rbr850 router and one satellite. In firmware admin it show a new firmware version v3.2.16.6 but it will not upgrade to it and the satellite says service unreachable. The past server firmware upgrades I have had to manually upgrade both the satellite and router. Any thoughts. I am thinking I will have to try and reset the main router. If I do this will I need to reset the satellite too?
- Chuck_MMentor
Try and disconnect any wired devices (other than PC) and attempt again. You dont have any other RBR50s attached do you?
- I bought the package that had the router and one satellite. I will try your suggestions as soon as I can.
I don’t think I mentioned I didn’t have this issue when I bought 4 months ago. It only started after one of the first firmware updates. Thanks
What browser are you using?
Edwardlotz wrote:
I hAve Orbi ax6000 rbr850 router and one satellite. In firmware admin it show a new firmware version v3.2.16.6 but it will not upgrade to it and the satellite says service unreachable. The past server firmware upgrades I have had to manually upgrade both the satellite and router. Any thoughts. I am thinking I will have to try and reset the main router. If I do this will I need to reset the satellite too?- Netgear cm1000
Have you factory reset the RBR and RBS, have the RBS in the same room as the RBR then walk thru the setup wizard to see if it picks up the new FW update for both RBS and RBR? I would use Edge, IE11 or Firefox browser to try this.
