aip5
Jun 05, 2025Aspirant
Help, I can't enter the system interface after changing the SXS80 model to RBS850
I changed the SXS80 model to RBS850 in Telnet, and wanted to flash the RBS850 firmware, but the firmware failed to pass the verification and could not be flashed. The current problem is that the mach...
Jun 05, 2025Guru - Experienced User
You can't put RBS850 FW on SXS satellites. Only using SXS FW works.
SXS are only compatible with SXR router. These are Pro systems. The RBS is a Home unit that only works with the RBR850 and 750 home systems.
