TWang1337's avatar
TWang1337
Apprentice
Jan 21, 2022
Hooking up RBS350 to RBR750
I have an RBR750 + RBS750
firstly i up RBR750 + RBS750 = v4.6.5.14
I also have an RBS350 which i've tried to hook up (which is supported by RBR750 on 4.6.5.14)
initially RBS350 is v4.4.0.10
then after i added the satellite, it auto updated RBS350 to v4.6.5.14.
this is a bit problematic. lots of drops and out of syncs
I have had alot of problem with RBR750 on 4.6.5.14 so i updated V4.6.7.5_2.1.7
which works well with RBR750 + RBS750
however RBS350 is still v4.6.5.14 and very unstable
Question - is there firmware V4.6.7.5 for RBS350?? one that might fix my problems
Thanks!!
  • CrimpOn's avatar
    CrimpOn
    Unless I am wildly mistaken, the RBS350 satellite does not interoperate with the 750 series product.  The 350 is a "dual band" product and the 750 is a "tri band" product.  The product data sheet for the RBS350 says "what do I need...." and the answer is a RBR350 router.
    • TWang1337's avatar
      TWang1337
      Apprentice
      Support was added!
      RBR750 / RBS750 Firmware Version 4.6.5.14
      Was this article helpful? Yes No | 10 people found this helpful in last 30 days
      Enhancements:
      Adds support for the RBS350
      Security Fixes:
      Fixes security vulnerabilities.
      • CrimpOn's avatar
        CrimpOn
        How cool. My Bad.  Since the new V4.6.7.5 is not a 'public release' yet for the 750, I would imagine that a similar release for the RBS350 would have to come through the same informal channel as the release for the 750.
        Good Luck
