TrueNet
May 23, 2020Aspirant
How can I see the wireless signal strength of connected devices to Orbi?
I just migrated from having two Pakedge Access Points. for a 5,800 sq. ft. house to a AX6000 Orbi Mesh system. So far I am very happy with the stability and strength. However to better manage the devices connected I used to be able to see on the Pakedge software the Wifi strength for each device, so if there was an issue I could either move the device or the Access Point. The Netgear software to manage devices seems way too basic. I was unable to set my Orbi as the main router passing though an AT&T Gateway and maybe that's where you do that, but I doubt it. I tried with all the help I found, but then I would have lost other things I wasn't willing to lose for the control of my home network.
TrueNet wrote:However to better manage the devices connected I used to be able to see on the Pakedge software the Wifi strength for each device, so if there was an issue I could either move the device or the Access Point. The Netgear software to manage devices seems way too basic.
AFAIK currently there's no way to check the single wireless device signal strength in the Orbi AX web GUI or app.
Alas, people who participate on this community forum typically have the WiFi5 Orbi system, not the new WiFi6. There is a community forum specifically for that product line: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
You are likely to get a more informed response by posting in that forum.
- Chuck_MMentor
CrimpOn wrote:Alas, people who participate on this community forum typically have the WiFi5 Orbi system, not the new WiFi6. There is a community forum specifically for that product line: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Where am I? I thought this was the AX forum!
You are in the correct forum. I was confused. I do not post often in the AX forum, so 99% of the notices I get in my email relate to posts in the WiFi5 forum. It was sloppy of me not to read more carefully.
Sorry.
You can load wifi analyzer apps on pads. WiFi Sweet Spots app as well to check speeds between the device and source AP.
- kildareLuminary
