sunilbhojawala
Jul 15, 2025Follower
How do I change my router 2.4from 5 ghz
How do I change my router 2.4 from 5 ghz
Jul 15, 2025Guru - Experienced User
What NG Orbi router model do you have?
Orbi system?
Most Orbi systems don't have a separate or can separate the main WLan. Newer systems have a separate IoT network that you can set 2.4 or 5Ghz depending on your needs.
