sunilbhojawala
Jul 15, 2025Follower
How do I change my router 2.4from 5 ghz
How do I change my router 2.4 from 5 ghz
CrimpOn
Jul 15, 2025Guru - Experienced User
It would help to know the reason for the question. While over 95% of typical "internet gizmos" are entirely compatible with Netgear Orbi routers, there are a few devices which have poorly written smartphone apps and be a struggle to get set up on the network. Once set up, people have no further issues. In those cases, there is usually a specific error message or indication in the app.
For many years, it was "common knowledge" (i.e. folklore myth) that devices require a WiFi system to be "2.4G only" in order to connect devices. Those days are long over.
More detail would help discover ways to help.
