KRBMT
May 07, 2023Aspirant
How do I distinguish the 2.4GHZ on ORBI RBR750 firmware V4.6.9.11_2.3.5
Hello. Does anyone have CURRENT info/scripts that will allow me to separate/distinguish the 2.4GHZ from the 5GHZ on the ORBI RBR750 router? I am trying to connect Defender cameras, which require that my Android phone/app be connected to the same 2.4GHZ channel that the cameras use. I am on Windows 11, as to where I can run scripts or telnet.
I have read numerous posts suggesting the use of options that are no longer available in my version of NetGear., firmware V4.6.9.11_2.3.5 I do not have the options to broadcast SSID, or to enable telnet so that I can do a set config of the 2.4GHZ channel to have a different name than the 5GHZ.
I tried (old) telnet_enable scripts that were listed in this community as solutions. None have worked. I was prepared to try the latest (2 yo) python script, but I do not see where the (required?) option of a MAC address is, in the Netgear firmware.
Please please help! I am so frustrated.
I am trying to setup these cameras to watch my horses while I go on vacation.
Thanks in advance, if this user group can come through for me:)
It would be a big help if you could post a link to these Defender cameras.
Most cameras that I have connected get set up by creating a QR code on the smartphone app and pointing the camera at the QR code. When I use a "QR reader app" to look at the same QR code, all it contains is the SSID and password of the WiFi system. Absolutely nothing about 2.4G or 5G.
I have connected at least four brands of WiFi cameras without doing anything to the Orbi. It would also be helpful if you can provide a link to the setup instructions and indicate "where it fails". (what step in the process)
Thanks
- KRBMTAspirant
Guard | How To Connect Your Defender Guard Camera. | VIDEO â Defender Cameras
The first link is to the cameras, the second is to the setup video.
During setup, after successfully scanning the QR code, the app creates a device hotspot, then goes into 'Detecting network security config', then says 'Unable to detect network security config. Please confirm your phone and device are connected to the same network'. My phone had still gone to the 5ghz, I assumed.
In that video, it says right at the start that you must have your phone connected to the 2.4ghz channel. I did not watch it before purchasing; previously I had setup Arlo 2.4ghz cameras just fine on my Orbi. I found the info about not working on 5ghz by going through the comments on the Defender cameras and problems other people had with getting to 2.4ghz. I did try one's suggestion of taking the camera and phone out to the shop to my Orbi satellite, which is using 2.4ghz (according to Netgear device info). Didn't work.
Thanks for the links. An interesting connection method. On page 9 of the printed instructions,
https://cdn.shopify.com/s/files/1/0115/0110/9314/files/IP4MCB1-UserManual-v2_WEB.pdf?v=1605717085
it is clear that their "WiFi Range Test" is intended to verify 2.4G signal strength at the proposed camera location. (This step is absent from the setup video.)
Step 6 on page 10 may hold the key. Can you open a QR Code scanner app and display what the information the QR code contains? (I have three different QR code scanners on my Android phone. All work about the same. Point at code. Read results.)
My suspicion is that the camera temporarily creates a WiFi hot spot and the smartphone app reads the SSID to look for from the QR code.
Another tactic that people have found to work in these situations is to turn off their home WiFi system and temporarily substitute a 2.4G WiFi channel with exactly the same WiFi credentials (SSID/password) as their home system. Some people have the old router that the Orbi replaced sitting in a box somewhere. [I have three previous routers.] My smartphone can create a WiFi Hot Spot that happens to be on 2.4G. I create a Hot Spot with credentials that match the Orbi and use a second smart device (tablet, usually. Sometimes an old phone.) to do the setup. After the IoT device is working correctly, power everything off, restart the home WiFi system, and "voila" all is good.)
So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was. Turn OFF all RBS temporarily as well.
Be sure that 20/40 MHz Coexistence enabled.Separation of SSIDs is NOT supported on Orbi systems.
- KRBMTAspirant
Any chance you could tell me what the exact option in the NetGear software is, to decrease the power output? I hope that is not done via my ISP, because they won't work with me due to the fact that I am no longer using their router, but the Orbi.
And, once I unplug the satellites and move my phone away from the router, how to I tell if it got hooked up to the 2.4ghz?
Thanks you guys for trying to help a newbie đ
Set the 5Ghz power from 100% to 25%. Under Advanced Tab/Advanced Settings/Wireless Settings
