4571BR
Jun 16, 2025Aspirant
I have a RBRE960 and 2 satellites
Same here, I have a RBRE960 and 2 satellites. Purchased it in May 2023, worked always fine till last week, when I had a power failure, did a reset and restarted the modem, router, and satellites as d...
Jun 16, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
When you did the factory reset, did you set up the system using the Orbi app or a web browser? https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Best practice to factory reset a Orbi system: Orbi Systems Manual Factory Reset Process | NETGEAR Communities
What mobile platform are you using? Apple or Android?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Can you access the RBRs web page at 192.168.1.1 at all with a wireless or ethernet connected PC?
What is the distance between the router š” and satellite(s)š°ļø? 30 feet or more is recommended in between RBR š” and RBS š°ļø to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite āāš°
Front LEDs on the RBR and RBS should be OFF for normal operation:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
- 4571BRJun 24, 2025Aspirant
I managed to get support from Netgear in the end. On their recommendation, I did a reset (Factory Reset) via the button at the back, this did work out after quite some time.
The ORBI app took tome time to setup, but in the onend it worked.
I also had the ORBI app installed als my Ipad and used this to do the setup initially.
I guess that the cause was due to the power cycling at the time of the power failure. At that time my feeling is that something went wrong with the startup of the router.
BR
Ben
