NetHobby
Dec 15, 2025Follower
I have one RBR750 and two RBS750 Satellites.
I have one RBR750 and two RBS750 Satellites. They are currently running on firmware code V7.2.7.15_5.1.16. Netgear support page states that there are two newer releases. I have my devices set ...
Dec 15, 2025Guru - Experienced User
So sometimes NG support doesn't push FW to ALL Orbi users. They used to however caused problems. Now days they seem to push new FW out in small batches. So if your system doesn't see it, doesn't mean you can't still get updates.
If you want new FW on your system, then users have the ability to update FW using the manual way and you can do this with this guide: Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
I use this all the time and works well.
Besure to update the RBS FIRST, then the RBR lastly.
If you want contact NG, you can here: https://www.netgear.com/support/home
- FURRYe38Dec 15, 2025Guru - Experienced User
Notice of FW updates are seen here with link to get to them: Orbi Firmware Releases | NETGEAR Communities
