cdsatpb's avatar
cdsatpb
Initial set up
A very basic question:  does the router in an Orbi mesh system connect to the ISP router, or does it replace the ISP router?  (I have a Utility Warehouse router which is currently plugged into the fibre (FTTP) terminal).  If it plugs into the ISP router, are devices connected over the mesh network on a separate network from devices plugged into the ethernet port on the ISP router?
  • michaelkenward's avatar
    michaelkenward
    There's no single answer to that.
    You can use it either way. You don't say what Utility Warehouse router or which Orbi system you have.
    Unless it does things that the Orbi can't manage, the easiest and least complicated option, is to get rid of the other router. Then just connect the Orbi to the FTTP terminal.
    If you do need the other router for some reason, you then have to avoid the "two routers" issue.
    What is Double NAT? | Answer | NETGEAR Support
    One way to avoid that is to put the Orbi router into access point (AP) mode.
    How do I configure my Orbi router to act as an access point? - NETGEAR Support
    but then you hit this:
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    You'll have to work out if that blocks things that are important to you.
    I'd start leaving the Utility Warehouse router gathering dust on a shelf somewhere.
    Just another user with time on their hands.
  • FURRYe38's avatar
    Could possible do both. Someting you'll need to ask your ISP about as some ISPs may differ on there requirements on what can be connected to there main debarcation terminal for there services to your home.
    IF there is a router at the ISP point,  This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
    New: https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
    https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
    https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2 first...
    https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
    If you deploy a orbi system then you would want all your devices connected to the orbi system so all devices can get connected on same system and communicate with each other with out interuptions.
