j4x4's avatar
j4x4
Installing ProtonVPN on Orbi CBR750
Hello Everyone,
I have an Orbi CBR750 with two satellites on my home network. I use Comcast-Xfinity for my cable internet access.
I need to install ProtonVPN on my router, but so far have been unable to do so. Is this possible? Has anyone made it work?
I am willing to buy additional equipment compatible with my existing setup if needed. I would prefer to avoid replacing all of my existing equipment since it was pretty expensive, and is still covered by warranty and support.
Thank you all in advance for any ideas or advice!
Cheers,
J
1 Reply
  • FURRYe38's avatar
    Installing external VPN apps is not supported on NG routers.
