Dryath
Jun 05, 2021Aspirant
Internet drops both wired and wireless RBS850
So i bought this setup recently when i moved house with the router and 3 satellites and all its given me so far is headaches.
Im on virgin media with the hub in modem mode directly plugged into the orbi router. My main pc is then wired directly from the router. I get frequent disconnects for a few seconds at a time on both wired and wireless and also speed drops from my normal 500mbps down to 40mbps on wired and wireless that requires a reboot to fix.
Not to sure whats causing this any ideas?
virgin hubs are notorious on here for not properly functioning in modem only mode.
If you put the virgin hub in router mode (disable its wifi) and then the orbi in access point mode, does it function properly?
- DryathAspirantSo i set the hub in router mode, disabled the wifi and changed the orbi to ap mode. Still getting around 40mbps when i should be getting 500+ and this is on my pc directly wired to the main orbi.
Check your connection rate on the PC to make sure the ethernet connection is 1000Mps.
You can do the same on the RBRs web page under Advanced Tab/Connection Status button and make sure it's connecting at 1000Mpbs to the ISP modem...
