BulletRouge
Dec 19, 2020Aspirant
IP conflicts with RBR750
SO, my new AX4200 config (router & 2 nodes) is a mess. Before I set it up, I changed my existing setup to lease IP addresses < 130, and waited for everything to have an IP address in that range before I did anything. Then I updated firmware all around, and did a factory reset before setting it up. Then before I let any devices connect to the Orbi network I changed DHCP to be > 130. then I let everything connect and virtually everything got new IP addresses. Then the problems began...
My wife yelled that our streaming device was pausing repeatedly. I checked the devie's IP address, and it was new. I rebooted the device for good measure. Same IP address. I went to the Netgear admin UI to look at the connected devices and it showed a completely different device on that IP address.
I was having the same issue on another streaming device, and same pattern. The IP address was showed as being assigned to a completely different device.
I have no other router or any kind on my network. I've had to swap back to my previous setup and everything is rock solid again...
Before I return it, any ideas??
BulletRouge wrote:SO, my new AX4200 config (router & 2 nodes) is a mess. Before I set it up, I changed my existing setup to lease IP addresses < 130, and waited for everything to have an IP address in that range before I did anything. Then I updated firmware all around, and did a factory reset before setting it up. Then before I let any devices connect to the Orbi network I changed DHCP to be > 130. then I let everything connect and virtually everything got new IP addresses. Then the problems began...
Devices control how they reset their network IP address assignments. If you change the DHCP settings in your router to use different IP ranges, you may need to restart each device to force it to acquire a new DHCP address. Old assignments causing IP address conflicts can occur but this is not necessarily an Orbi issue.
Also, why are you changing the IP address range in your Orbi? Are you also setting up some devices with static IPs? That is another way to create IP address conflicts unless done carefully and correctly. My recommendation is to stick with DHCP address reservations for all your devices but configure them in the Orbi to be "reserved" so they are unlikely to change. For best results, after configuring your Orbi IP address ranges force a reset or reboot of every device so they get a fresh, and current, DHCP address from the Orbi.
- BulletRougeAspirant
RIght, the reason for using a non-overlapping DHCP range was part of the troubleshooting; I wanted to be able to see when the Orbi assigned a new number to the device, and when it hadn't. So that I could go to any lingering devices and reboot them...
But the conflicts I am describing here are all in the Orbi DHCP range.
Probably giving all my devices reservations might work, but seriously the DHCP server shouldn't be doing this...
BulletRouge wrote:I went to the Netgear admin UI to look at the connected devices and it showed a completely different device on that IP address.
Also, the Orbi admin website is usually pretty accurate but I don't trust the app as much as the admin website. In this case, did you reset/reboot the conflicting device so it gets a fresh IP address? The problem seems that it was using an older address but should be able to get a new and non-conflicting one.
I am only using the website.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?So does the RBR and system work if you don't change the IP address range?
What range are you using? 192.168.1.2 thru .130?
I currently use 192.168.0.100 to .150 and don't see DHCP issues. Having ranges on either side of this default DHCP pool size leaves me room for static assigned devices. Everything with in the pool can be reserved IP assigned.
Be sure that when you set a new pool size, that you reboot ALL ther devices as well after the RBR configuration is applied. Be there are no static assigned IP addressed devices with in your new pool size.
FURRYe38 wrote:What Firmware version is currently loaded?
I am using Verizon FiOS, and I connect my router directly to that. Only one router on my network.
I did let the Orbi using the default range, but I had lots of conflicts. That's why I reverted back to my previous router, and setup non-conflicting IP ranges for them before trying again. I wanted to have confidence that Orbi wasn't assigning an IP address to a device that had not requested a new IP address yet.
Well when setting up any new router it's best to power OFF all devices while you get the new router setup. Then after the new router is set up, power one the devices one at a time and let them and router get IP assignments.
