Rogelio1's avatar
Rogelio1
Apprentice
Jul 09, 2022
iPhone 12 Pro loses WiFi connection with RBR850
I’ve had the exact same problem for the last 1.5 years and NOTHING has solved this. iPhone 12 Pro — I’ve done everything mentioned above — static IP address, factory reset Orbi, CTS changes, dropped power to 50%. I find it odd that my prior iPhone XR nor my wife’s iPhone 13 have issues; neither does my iPad Pro nor my 14” MacBook Pro. The issue always occurs when I walk quickly or back and forth between router and/or satellites that are somewhat equidistant in a line setup. My router is 40 feet from Sat1 hardwired, and sat2 is 30 feet from Sat1 (wireless backhaul to sat1).I’m on the latest Orbi firmware (4.6.8.5) however every prior version has had this behavior. It seems illogical to say I need to place these in different locations — something specific is going wrong with the acquisition of an IP lease to the phone between Orbi devices. The iPhone 12 will be connected to Wi-Fi consistently but have no actual internet / webpage loads — data just hangs until it resolves itself in about 2-4 minutes… or if I forget the Wi-Fi and re-addit, or if I reboot my phone. I’ve also reset all internet connections and factory reset my phone even. I have a separate iPhone 12 as my work phone that does this exact same thing as well. I previously had the Orbi rbr50 kit and this never happened on the same devices. I’ve optimized the channels being used using a Wi-Fi analyzer and there is no other interference that should cause this (ax is on without 20/40 coexist). I’ve even replaced my iPhone 12 Pro once (due to a cracked screen), and the replacement which I did not restore from a backup did the same thing. I’m sort of out of options here having tried almost everything that has been suggested in this post and every incarnation of others (disabling private Wi-Fi address / tracking, disabling Wi-Fi-assist, etc.).
  • FURRYe38's avatar
    What is your current WiFi and Advanced WiFi configuration look like on the RBR?
    I have 12 Pro Max and have never had any issues with it connecting to the RBR ever. iOS 15.5
    I run manual channels 1 and 40, CTS 64, WMM enabled, 50% power, 25% if I run two RBS. WPA2/AES only.
    Possible your one 12 Pro could be faulty if other iPhones are working.
    • Rogelio1's avatar
      Rogelio1
      Apprentice
      Wifi:
      [x] Enable 2.4 Ghz
      [x] Enable 5 Ghz
      2.4Ghz Channel [03]
      5Ghz Channel [48]
      Security Options [WPA2-PSK [AES]]
      Advanced Wireless Settings 2.4GHz:
      [ ] Enable 20/40 MHz Coexistence
      [x] Enable WMM settings (2.4 GHz b/g/n/ax)
      CTS/RTS Theshold [64]
      Preamble Mode [Automatic]
      Transmit Power [100%]
      Advanced Wireless Settings 5GHz:
      [x] Enable WMM settings (5 GHz a/n/ac/ax)
      What is the size of your home? Sq Ft? What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
      See above.  House is 1500 Square feet but Sat 2 is placed in a separate (not in 1500 Square foot) location in a She-Shed / property is 6000SqFt
      My router is 40 feet from Sat1 hardwired, and sat2 is 30 feet from Sat1 (wireless backhaul to sat1). I’m on the latest Orbi firmware.
      Two sets of walls between sat 1 and sat 2.  Multiple walls between Router and Sat 1 (hardwired)
      The channels I have them on are based on WifiExplorer surveys to limit interference of closest neighbor wifi.
      I've tried 50% power, and the behavior persists.  I've effectively tried 3 different iPhone 12's (my current pro before it was replaced, when it was replaced, and then a work iPhone 12) and this behavior exists/existed on all.  Behavior did not exist on prior iPhone XR, wife's current iPhone 13, iPad 12.1 Pro (3rd gen), 14" Macbook Pro.
      I have not tried dropping power to 25% -- I suspect this applies not only to the SSID broadcast but to the backhaul, yes?  (if so, I'd imagine that sat2 would have throughput drop, and also have signal drop on Sat 1 from clients connected since it's on the far-end of the house from the router on the other side.
      The setup is in a line -- router on far South-side of house; Sat1 hardwired to Router on far North-side of house (40 feet and multiple building materials between); Sat 2 off main-property in a She-Shed 30 feet southwest south of Sat1 (but with two thick walls between).  Typically when I'm in my master BR adjacent to the bedroom where Sat1 is (but somewhat closer to Sat2), I see devices all connect to Sat1;  I see all my devices inside the house connected to router when closer to the South side of the house; generally when I walk outside of my master BR or closer to the She-Shed and further North, I see the device switch to Sat2.  When I lose connection, it tends to be when I walk from my master BR towards the living room router, then quickly back to my master BR -- I'm guessing the client or satellite flips out and can't maintain a lease (even if I've manually set the iPhone to a static IP I've reserved for my iPhone's MAC address having turned off private wifi feature).
      • FURRYe38's avatar
        Wifi:
        [x] Enable 2.4 Ghz
        [x] Enable 5 Ghz
        2.4Ghz Channel [03] Try 1,6 or 11. 3 and other channels are not primary ones to use. Only used by the system. I use 1 and 40 here.
        5Ghz Channel [48]
        CTS/RTS Theshold [64] Try 2307
        This size of home, only 1 RBS would be recommended.
        https://youtu.be/UR0viMLISz4
        I have not seen this behavior on my iPhone12 Pro Max or MacBook Pro 2018
        I have not tried dropping power to 25% -- I suspect this applies not only to the SSID broadcast but to the backhaul, yes?  Not if ethernet connected. (if so, I'd imagine that sat2 would have throughput drop, and also have signal drop on Sat 1 from clients connected since it's on the far-end of the house from the router on the other side.
        Let try reducing the power on the RBR. I use 50% all the time on my primary Orbi and I have a 5000sq ft home. Plenty of coverage. RBS are ethernet connected as well.
        What CAT# lan cable is being used for the RBS from the RBR?
        There any kind of LAN switch in between the RBR and RBS?
        The setup is in a line -- router on far South-side of house; Sat1 hardwired to Router on far North-side of house (40 feet and multiple building materials between); Sat 2 off main-property in a She-Shed 30 feet southwest south of Sat1 (but with two thick walls between).  Typically when I'm in my master BR adjacent to the bedroom where Sat1 is (but somewhat closer to Sat2), I see devices all connect to Sat1;  I see all my devices inside the house connected to router when closer to the South side of the house; generally when I walk outside of my master BR or closer to the She-Shed and further North, I see the device switch to Sat2.  When I lose connection, it tends to be when I walk from my master BR towards the living room router, then quickly back to my master BR -- I'm guessing the client or satellite flips out and can't maintain a lease (even if I've manually set the iPhone to a static IP I've reserved for my iPhone's MAC address having turned off private wifi feature). Either set a static IP address ON the phone or reserver an IP address for the phone ON the router. Do not use both methods at the same time.
