silentk
Sep 04, 2022Aspirant
Is NAT loopback supported on Netgear Orbi RBKE963
Hi all, First time posting here, nice to meet you all. I want to purchase a Netgear Orbi RBKE963 or the B (black) version. I have one specific requirement: - Does it support NAT loopback?...
CrimpOn
Sep 05, 2022Guru - Experienced User
DodgeDeBoulet wrote:
I do not believe the RBKE963 supports NAT loopback. That was something my previous router, a NetGear R9000 (running dd-wrt, not Netgear's firmware), did support and I was a bit dismayed when it went away upon installation of the Orbi. It wasn't a tragic loss, though, as I only needed to to monitor webcams from my phone when away from home; I had other means to monitor them while in the house.
Could you please describe the specific test which verified that NAT Loopback is not supported on the RBKE963?
For example, on my RBR50 I forwarded HTTP to 192.168.1.4 (an Epson printer), opened Edge, entered http://<my public IP address> and up popped the printer web page. What was your test?
DodgeDeBoulet
Sep 05, 2022Apprentice
I configured my phone to connect to my web cams via the public IP and ports, after creating the appropriate NAT rules in the Orbi configuration. I could not connect while attached to the WLAN, but could connect via WAN/4G/5G.
With the new firewall and corresponding NAT rules (and hairpinning enabled) I am able connect using the public address from both WLAN and WAN.
- CrimpOnSep 05, 2022Guru - Experienced User
Thanks for the explanation. Disappointing to be sure. ☹️
I had considered using port forwarding to provide access to security cameras and decided it was "too much detail" for me. Since any given port (or range of ports) can be forwarded to only one internal IP, that meant I would have to define (and remember) separate external port numbers for each camera that would forward to the internal port number on different internal IPs.
Such as, supposing the internal port was 9000:
- Camera 1 would be public IP port 9001 forwarded to internal IP port 9000
- Camera 2 would be public IP port 9002 forwarded to internal IP port 9000
- Camera 3 would be public IP port 9003 forwarded to internal IP port 9000
- and so on.
While I am OCD enough to have worked this out and created browser bookmarks for each camera, I was already using the manufacturer's "cloud app" when away from home, so being able to access cameras from home with both LAN IP and NAT Loopback just wasn't worth the effort. I only use NAT Loopback to verify that port forwarding is working.
Appreciate you taking the time to report your results. This still begs the question of why Netgear would remove a feature that existed in every previous router model.
- DodgeDeBouletSep 05, 2022Apprentice
CrimpOn wrote:Thanks for the explanation. Disappointing to be sure. ☹️
- and so on.
It absolutely was a PITA with the Orbi's NAT configuration page. Slow and cumbersome.
OPNSense allows you to define aliases for ports, port ranges, hosts, address ranges, and other things that make it much simpler to configure NAT and other firewall rules. You can also enable its nginx plug-in as a reverse proxy that lets you route a URL path to a specific IP address/port combination. I haven't actually played with this yet, but I know it's possible.
You mean like the ability to assign separate SSIDs to 5GHz and 2.4GHz radios? And network isolation between VAPs*? Nah, they'd never do such a thing ... 😡
* The IoT WLAN is directly connected with the "main" LAN/WLAN. No protection from bargain-priced foreign hardware that might have less than honorable intentions on your network.
