Sameem
Nov 05, 2025Aspirant
Is v7.2.7.15 stable?
Hey guys,
I have an Orbi rbr 750 with two rbs750’s spaced out not too far. This has been happening for a while now but depending on the software version it becomes unstable. Constant disconnects then reconnects.
And by the looks of it v7.2.7.15 looks unstable. It’s started again. Does anyone know a stable version I can use?
kind regards,
Any progress or feedback on this?
I put my 963 series online yesterday. Work well.
Sameem wrote:
Hey guys,
kind regards, - liamscorLuminary
v7.2.7.15 has been rock solid for me on the 960. I did a factory reset and set it up from scratch via the web GUI. The only key things that I know of to change that are important are that IPv6 is disabled and then set one of the non-overlapping channels on the 2.4GHz band, which varies depending on your region. See below:
https://kb.netgear.com/1027/Selecting-wireless-channels
Software version of what? Orbi app or routers web page? Could use more details.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰Try disabling the following and see:
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter. There was a known issue on past couple of FW versions where IPv6 feature is not working.
