rpd1116
Apr 04, 2026Aspirant
Issue when rebooting RBR750P - router continually cycles and requires reset
I have an issue when rebooting my RBR750P. Every time I do a reboot, the router stops working. It will come back up, but I am unable to connect to it. My Wifi network will appear on my devices but I ...
Apr 04, 2026Guru - Experienced User
have you tried reinstalling the firmware to the router? maybe its corrupt.
AFter that, try the factory reset and reinstall.
Don't use a saved configuration when you reinstall.
- rpd1116Apr 04, 2026Aspirant
Yes, I did try reinstalling the firmware, although I could try again as that was a while back. Is there just one reset or is there soft and hard/factory? If there are two types I think I’m only doing the soft reset
- FURRYe38Apr 04, 2026Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does both WAN-LAN Show stats on the RBRs web page under Advanced Tab/Internet section and RBR IP address/debug.htm both show system up time as all being reset when this happens?
Have any RBS deployed?
Two different way to do a factory reset:
- Press the reset button in back for 15 seconds then release.
- Follow this guide -
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
