mrwkbrdr's avatar
Jan 14, 2020
Laptop unable to see SSID wifi6
Lenovo laptop unable to see SSID with AX enabled. Turned of AX and SSID can now be seen.
  • plemans's avatar
    Does your laptop of an intel wireless card? If so, go to the intel site and update the driver on it. The device manufacturers (sony, lenovo, etc) aren't good at doing the update so you have go directly to whoever makes the part.
    intel cards had issues with earlier drivers not being able to see ax. Try updating it.
    • Chuck_M's avatar
      Chuck_M
      Mentor
      As said previously, this is typically an issue with an outdated driver.
    • mrwkbrdr's avatar
      mrwkbrdr
      Star
      Driver has the latest available.
      • FURRYe38's avatar
        What is the model# of the wireless adapter card?
        Do other wifi devices work while AX mode is enabled?
  • FURRYe38's avatar
    What FW version is currently loaded on the Orbi?
    • mrwkbrdr's avatar
      mrwkbrdr
      Star
      FW version 3.2.9.2_1.2.4
  • FURRYe38's avatar
    Any progress on this?
    Ensure WiFi adapter drivers are up to date on the laptop...
