scleary81
Jun 09, 2025Aspirant
Loss of connection between satellites
I am currently running the Orbi wifi 6/6E system, with a router unit and satellite. I have noticed a consistent problem of maintaining the paired connection between devices, based on proximity to sat...
CrimpOn
Jun 09, 2025Guru - Experienced User
scleary81 wrote:the known Orbi - iPhone SE issues
Alas, I am not aware of any documented issues concerning Orbi routers and iPhone SE. There are some very long conversations about the new WiFi7 products and the very latest iPhone models:
WiFi 7 and iPhone 16 Pro Max along with wireless backhaul | NETGEAR Communities
Perhaps this particular iPhone SE has "WiFi issues". It might be interesting to experiment with other mobile devices (phones, tablets, laptops) to see if any other device displays the same problems that that specific iPhone SE did.
p.s. I envy that you have a working iPhone SE. I am one of the few who sincerely prefers a "small phone" and my Sony Xperia Compact died. There are zero Android phones with a size to match the iPhone SE.
- scleary81Jun 10, 2025Aspirant
Gotcha, nonetheless, I really appreciate your help. I think I have a new rabbit to chase down a hole on this one, hopefully it ends with a solution. Thanks again for your input and take care.
