EyalS's avatar
EyalS
Tutor
Jul 23, 2020
Low network speed on one satellite (out of 2) - Orbi WiFi 6 System (RBK853) AX6000
When connected to one of the satellites, either WIRED or wireless, I'm getting a maximum of 5mbps. Tested on a desktop with https://www.speedtest.net/.
When replacing the satellite with a switch, I'm getting again 80mbps (wired).
Same happens with iphone 11 pro. It gets a maximum of 5mpbs when connected to this specific setellite. and around 70 mbps when connected to the other satellite or the main router.
Someone have an idea what could cause that?
10x,
EyalS
  • What Firmware version is currently loaded?
    What are you results of the other RBS?
    Press the back reset button for 15 seconds then release.
  • FURRYe38's avatar
