bassvic's avatar
bassvic
My iPhone 13 pro would loss the internet connection
My RBK752 and one additional RBS750 satellite system has the same issue. My iPhone 13 pro would loss the internet connection or wifi connection occasionlly after walking through/between the satellites, and the router covery area is not affected. I have tried many ways to fix / configure the problem, including those mentioned above. The problem persists.
  • FURRYe38's avatar
    How many RBS doe you have deployed?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    What CTS value are you using currently? Try 500 or 2347?
    • bassvic's avatar
      bassvic
      Firmwire: 4.6.8.5
      The orbi ax system is connected to Taiwan CHT modem/ONT model RTF8217, via PPPoE
      The system include one RBR750 and two RBS750, using wired backhaul
      My home: Three floors, each floor 18.2 sq ft.
      The router is located on second floor and the satellites located on first and third floor.
      Channel: 2.4G: auto / 5G: 48
      I have tried to set the 2.4G power to 50% and CTS/RTS value to 2347 but the issue persists.
      • FURRYe38's avatar
        bassvic wrote:
        Firmwire: 4.6.8.5
        Are the RBS directly connected to the RBR in back or is there a patch panel or LAN switch in between?
        My home: Three floors, each floor 18.2 sq ft. <18 sq ft? Thats really a small place. Can you confirm the total size of the home? ####sq ft?
        Turn OFF both RBS, does the phones keep connected or do they still disconnect from the RBR?
        Then turn one RBS back ON. Leave the 2nd RBS OFF. What happens here with the iphones?
        Channel: 2.4G: auto / 5G: 48 <Try setting channel 11 and 48.
        What iOS are you using on the iPhones?
