FAMECITY
May 28, 2024Aspirant
Nest Thermostat and Lock unable to connect
I have RBR 850 with 2 satellites and have no connectivity issues with the exception of my Nest Thermostat and 2 Nest locks that will not connect. I have 6 Nest cameras, 2 Nest Hello connected with no issues. I contacted support and they had me use the IoT but that also did not work. I am able to connect each of these devices to my mobile hot spot where they connect and operate properly. When I switch them to the Orbi, they stay connected for about 2 minutes and then disconnect.
Hoping someone has some suggestions.
How is the IoT network configured?
Something to contact NEST support regarding there products.
- FAMECITYAspirant
Updated firmware last night to latest version.
IoT was configured to 2.4ghz per Netgear support
I have contacted Nest several times but it looks like an Orbi issue since I am able to connect to other networks.
What version number of FW is loaded?
How is the 2.4Ghz IoT network security configured? Try with NONE for security as a quick test to see if anything connects?
