norfolkgeorge's avatar
Jul 12, 2023
NETGEAR RBS750 connection to 2 satellites
This router and two satellites has been in use for just over a year. However, it is now not working properly. I can connect both satellites by ethernet but neither by wireless even when within a couple of meters. Have removed and added a few times but only works using ethernet.
Is this a known problem? Any suggestions?
  • plemans's avatar
    did you try factory resetting it?
    what firmware is on the router and on the satellite?
    what modem/gateway is the router connected to?
    • Yes, I tried factory reset to no effect.
      For router:
      Hardware VersionRBR750
      Firmware VersionV4.6.9.11_2.3.5
      GUI Language VersionV3.0.1.51_2.1.30.3
      Operation ModeAP
      For Satellites: Hardware Version: RBS750 and Firmware Version: V4.6.3.16
      • plemans's avatar
        I'd upgrade the firmware to the newer one for both the router and the satellites. Make sure to upgrade the satellites first, then the router. Then give them a couple days and see if anything's connecting to the satellites.
