SydneyLad
Feb 12, 2026Aspirant
New RBS750 (satellite) ... can't check/flash the firmware
Hi all, Having some challenges with a new RBS750 satellite to connect to a pre-existing setup of RBR750 and another RBS750. The latter 2 are on V7.2.6.31. I do not know what the new satellite...
Feb 12, 2026Guru - Experienced User
Is this a new RBS or a used one?
You should be able to access the RBS web page at 192.168.10.250 if you set a static IP address ON the wired PC to 192.168.10.49, 255.255.255.0 subnet. Factory reset the incoming RBS by pressing the reset button for 15 seconds then release. Then give about 5 minutes then try the IP address of the RBS
Orbi Satellite (RBS) Self-Service Web Page Access | NETGEAR Communities
Which IP address is responding to pinging of the RBS?
Might try a full on 30-30-30 reset on the RBS, Then try the self service IP address.
