Disturbd1's avatar
Dec 28, 2021
No devices connected through RBS750
I have the 2-pack CBR750/RBS750, purchased in 2020 when they were released. Firmware on CBR750 is latest - V4.6.5.8. Firmware on RBS750 is also latest - V4.6.5.14.
For a few months now, I have not been able to successfully connect and maintain any 5gHz devices to the satellite. It successfully connects a 2.4gHz smart home device that I use, but literally every other device is ignored for some reason.
In my attempts to reset the satellite as per instructions in this thread , it will NOT reset. No amount of power-cycling, reset-button holding, etc seems to work. Its behavior is as follows:
  1. Power is disconnected (and I remove it from attached devices in the web UI)
  2. Power is reconnected with the satellite near the main unit
  3. White light flashes for about 5-10ish seconds
  4. White light pulses for several minutes after that (anywhere from 2-5+)
  5. Since it never turns solid white, during the pulsing white phase, I hold the Reset button for 15+ seconds. This does not change the pulsing white light; it might "restart" the pulsing phase but it never changes other than that.
  6. During the while light pulsing, I notice it consistently re-adds itself to the main unit via wifi backhaul, but initially shows up as "wired" and the light on the satellite turns solid blue.
  7. Solid blue light disappears, satellite is connected, and is indicated as being connected to the main unit via wifi.
What am I missing here? Why can't I effectively reset this satellite? More importantly: am I the only person who can't get devices to connect and even favor the satellite when it's closer?
