pshah3334
Oct 14, 2021Tutor
Not able to have multiple SSID on Orbi
Submitting this topic again in correct forum (instead of general forum).
Router - Orbi RBR753 (AX4200)
Firmware version - V4.6.5.14
Main OS for my devices - Windows
2 issues after upgrading to this new router from this month -
1. I have several devices which support WPA3 protocol but some support only WPA2 or below. I would like to have separate SSID by using particular security protocal. So I can utilize WPA3 for the devices which support this protocol. Devices which do not support it I will use different SSID. I research forum and it looks like it is not supported at all and I have to use guest network to separate it out. Is this correct? If it is then not sure why Orbi has this type of design and why it does not support this simple user's need and why should I use guest network? If multiple SSIDs are not supported by design then wireless settings configuration should have an option to use either WPA2 + WP3 as one of the security option.
2. Computer which uses guest network (as it supports only WPA2 or below); I am keep getting disconnected from internet. All other devices are working fine at the same time and no issues at all. I called Netgear support team and they asked me to use Google DNS (instead of ISP's DNS) but no luck yet. Do not know this is happening because I am using guest network OR WPA2 protocal? No idea.
FYI - I also tried using USB wifi adapter as initially I thought my built in laptop's wifi card is dying but that did not help.
Any help will be appreciated here.
You may need to factory reset the system and power the system OFF as well.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150287/highlight/true#M21560
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150391/highlight/true#M21575
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150417/highlight/true#M215792 issues after upgrading to this new router from this month -
1. I have several devices which support WPA3 protocol but some support only WPA2 or below. I would like to have separate SSID by using particular security protocal. Separation of SSIDs is not support on Orbi systems. So I can utilize WPA3 for the devices which support this protocol. Devices which do not support it I will use different SSID. I research forum and it looks like it is not supported at all and I have to use guest network to separate it out. Is this correct? Yes. If it is then not sure why Orbi has this type of design and why it does not support this simple user's need and why should I use guest network? If multiple SSIDs are not supported by design then wireless settings configuration should have an option to use either WPA2 + WP3 as one of the security option.
There was problems with WPA2 and WPA3 working together and the WPA level. NG removed the mixed mode option. Not sure if or when NG will fix that.
If other devices are working ok on Guest Netowrk and this on Computer does not, I would review the computer for issues. Ensure it's wifi adapter drivers are up to date. Contact the mfr of this adapter for additional Help and support.
Thank you for your quick response on my questions.
Additional information you asked for - ATT Uverse Modem - 5268AC FXN
For #1 - Not sure when I spent $400 for router why can't have this simple feature (to support devices both based on WPA2 and WPA3 protocols). I hope NetGear team works on this as priority basis as many people raised this concern.
For #2 - I already used USB adapter (and not what comes with my laptop) and same behavior. When I ran ipconfig command it is not using same gateway as I am seeing on other devices. According Netgear support team for some reason it uses modem's gateway for some reason. But they do not know why? Also, this issue started after changing my router to use WiFi6 capabilities.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would post about asking NG getting Mixed WPA modes on Orbi AX systems here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Or open a support ticket and let NG know about this:
