Mastra11
Jul 30, 2026Apprentice
Numerous DHCP requests Tesla Powerwall 3
Good morning, I have a Netgear Orbi 753 router and two satellites connected to Wireless Backhaul, satellite one connected to the router and satellite two connected to satellite one. I have a Tesla Powerwall 3 solar battery that is connected to Wi-Fi. I've noticed that it often switches bands continuously from 5GHz to 2.4GHz and vice versa. Consequently, when checking the Orbi router logs, I also see numerous DHCP requests, one after the other, for the battery's IP address. Is there a way to prevent this band switching and constant DHCP requests from happening? I've noticed (I don't know if this has an impact) that it often does this when, after a reboot of the Orbi, Orbi uses 40MHz for 2.4GHz Wi-Fi. Currently, it is active, but I've never turned it off—the 2.4GHz 20/40MHz Wi-Fi option. I look forward to your replies and thank you.
The powerwall wifi client is choosing to switch.
Options are to
- set up a 2.4 ghz-only IoT network and switch the powerwall to that network.
- move one of the satellites closer to the powerwall, in hopes of getting a better 5 ghz connection.
- Mastra11Apprentice
Hi, thanks for your reply. I can't activate the IoT network, and I can't move the satellites closer together because they're placed in specific spots to cover the house. Why does Orbi sometimes use 20MHz and sometimes 40MHz in 2.4GHz? Thanks.
Sounds like the device is ping ponging around and can't get locked in to the closer or one particular signal. Saw this on my 850 series years ago.
What FW is currently loaded on the RBS and RBR?
What channels are you using?
20/40Mhz channel co-existence is for neighboring wifi signals that you maybe around on 2.4Ghz. Long time policy. You can force 40Mhz only on 2.4Ghz.
Distance in between the RBR and the RBS and each other? in Feet.
- HappyCatVirtuoso
A WiFi extender has been used by many Community members to address similar problems. i.e.
- Purchase any brand of WiFi extender. (Amazon offers them for under $20.)
- Locate the WiFi extender in a convenient spot where it gets a good signal from the Orbi system and is relatively close to the Powerwall.
- On the WiFi extender, create a 2.4G WiFi network with a unique name.
- Connect the Powerwall to this unique name, which will in turn connect it to the Orbi system.
- Using Attached Devices, learn the MAC address that the WiFi extender uses for the Powerwall and use that MAC address to reserve an IP address on the Orbi for the Powerwall.
Going forward, the Powerwall will connect only to the WiFi extender and will get the same IP address from the Orbi.
Not a good solution though. At best a hack.
FWIW, it isn't clear there actually is a problem that needs solving. The powerwall monitoring is working properly, so the DHCP requests and band switching aren't causing any operational issues. So I think it is perfectly ok to do nothing at present.
The simplest next step is to update the firmware, and set up the IoT network - that would prevent the band switching. Though the powerwall might still make multiple DHCP requests (particularly if it doesn't need to stay connected to the wifi network).
