minetworking
May 13, 2020Aspirant
Optimizing for the best wifi 6 mesh setup
Hi there,
We are moving in to a 3,000 sq ft house that's fully wired with Cat6 and have AT&T fiber 1GB. As a result, I'm trying to determine what the best wifi 6 mesh system is to purchase?
Do I get the Orbi 6? Can I pair them over the existing ethernet cables? If I can pair over ethernet, do I need the extra backhaul band?
Or do I get the Orbi AX4200 if I can pair over ethernet? What will be my rough speed difference between the two?
Would love anyone's recommendations on what best to do.
Thank you!
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Review the spec sheets for the 850 and 750 series. I believe the main differences are the connections rates seen on the wifi radios.
https://www.netgear.com/support/
- minetworkingAspirant
Thank you for your prompt reply. It seems AT&T modem can be configured for passthrough (https://forums.att.com/conversations/att-internet-equipment/strict-nat-bridge-mode-what-is-ip-passthrough-can-i-enable-on-my-arris-bgw210-or-like-router/5defbfffbad5f2f606ad5ed2)
*If* this is the case, what do you recommend betweent he 750 and 850? Is it worth paying up for the 850 if the wired connection points will be the same speed?
I don't have any experience with 7 series AX System. I presume it should compare well to the 8 series system. Something you could get from a retailer that have a good refund policy and try it out. If it doesn't work to your liking, return it and get a refund.
