SparkyNuts
Aug 28, 2022Aspirant
Orbi 750, Could Not Get Good Ethernet Connection, Faulty Hardware??
We've been using a Netgear WNDR3700 wifi router with a Motorola SB6141 modem. Comcast is our service provider, with download speeds of 100Mbps. Our desktop is connected to the wifi router via ether...
SparkyNuts
Aug 29, 2022Aspirant
The connection speeds are good when the computer is connected directly to the modem.
The speeds are good when the computer is connected via ethernet to the WNDR3700
The speeds are good when my iPhone is connected via wifi to the WNDR3700.
The speeds are unworkable when the Orbi is involved, whether or not it's a wifi or eithernet connection. The problem definitely seems to be with the Orbi router itself, and not even with just the wifi setup but also with the Orbi's ethernet connection to the desktop.
ekhalil
Aug 29, 2022Master
Ok, I understand, but what does the speed measurement in the Orbi app or the Orbi web GUI gives you please?
- SparkyNutsAug 29, 2022AspirantAh I understand.
Orbi reported about 5Mbps download as well A lot of time, Orbi was showing the magenta light on the router. I think I only used the Orbi speed test once, then speedtest.net
One odd detail, is that for about three minutes or so, right after completing the setup, Orbi’s Ethernet connection to the desktop was giving me over 100Mbps download. Then it just ground to a crawl and even a factory reset and second setup did not resolve the issue.- ekhalilAug 29, 2022Master
This looks to be an issue with the connection between Orbi and the cable modem. Have you tried another cable? To which port in Orbi do you connect the cable from the modem? Have you tried a factory reset of Orbi router? Please try factory reset and use only the router first (without any satellites, then if all goes well add the satellites.
What firmware do you have on Orbi. The latest firmware is v4.6.9.11. Working very well for me. It worths trying it. https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR750-RBS750-Firmware-Version-4-6-9-11-Released/m-p/2250766#M37072
- SparkyNutsAug 30, 2022AspirantI did not try a different cable connecting Orbi to the modem. I used the same yellow cord that was connecting the WNDR3700 to the modem. The cord was plugged into the yellow port on the Orbi.
I did do a factory reset a couple times, to no avail.
I was able to update the firmware to the most recent version before the download speed slowed to a crawl.
I think it’s much more likely that made some mistake than that the Orbi had a defect.
We ordered another one and I’ll try that (we’ll return the first one). If I still have problems, then I’ll know it’s me because I can’t believe I’d get two defective systems.
Could the slow speeds have been related to the protective software running at first?
