Willys1994
Sep 14, 2022Aspirant
Orbi 750 Series Tri-Band WiFi adding NETGEAR 8-Port Gigabit Ethernet Plus Switch
Before I purchase NETGEAR 8-Port Gigabit Ethernet Plus Switch (GS308E) I wants clarify, will this work with my netgear Orbi RBR750 and satellite and will it give me issues at all and can ...
CrimpOn
Sep 14, 2022Guru - Experienced User
The only problems people see with switches are when the satellite is connected to the router through some switches.
If the satellite remains connected directly to the router, then switches can be connected to both the router and satellite so that many devices can connect to the network.
The switch should not be connected to the modem.
