Willys1994
Sep 14, 2022Aspirant
Orbi 750 Series Tri-Band WiFi adding NETGEAR 8-Port Gigabit Ethernet Plus Switch
Before I purchase NETGEAR 8-Port Gigabit Ethernet Plus Switch (GS308E) I wants clarify, will this work with my netgear Orbi RBR750 and satellite and will it give me issues at all and can ...
Sep 14, 2022Guru - Experienced User
Be sure to disable any and all IGMP protocols on the switch and if present in the switches menus, any Green Ethernet options.
Be sure to use good quality LAN cables. CAT6 is recommended.
Willys1994 wrote:
Before I purchase NETGEAR 8-Port Gigabit Ethernet Plus Switch (GS308E) I wants clarify, will this work with my netgear Orbi RBR750 and satellite and will it give me issues at all and can it connect to the router or satellite or does it need be connect to the modem?
option
Please don’t recommend it I know difference between a unmanaged switch and manage switch. I don’t want a unmanaged switch
I Owned it: Orbi 750 Series Tri-Band WiFi 6 Mesh System, 4.2Gbps, Router + 1 Satellite
Planning to purchase from Amazon: NETGEAR 8-Port Gigabit Ethernet Plus Switch (GS308E) - Desktop or Wall Mount, Home Network Hub, Office Ethernet Splitter, Silent Operation, Black
