vmahadevan77's avatar
vmahadevan77
Orbi 760 and Vodafone FTTP in the UK
Hi,
I've just installed my new Orbi 760 and Satellite systems connecting to my Vodafone FTTP (gigabit fibre)
My FTTP box on the wall connects to my Orbi main modem/router unit via ethernet and I have connected 3 orbi satellites(2 via LAN and 1 via wireless) to the main Orbi router and  everything seems to be working.
However, the download speeds are shocking(I was consistently getting 600mbps/150mbps download/upload speeds with Vodafone's Ultrahub modem/satellites
Is there anything else I should be doing? I have updated firmware, changed wifi channels, rebooted, factory reset etc.
I'm not a total newbie at Wifi networks, but double NAT and DMZ is a bit above my head.
Is there an idiots guide, or has anyone got any tips for setting this up correctly?
Thanks,
MV
  • plemans's avatar
    You put what you were getting, but what are you getting now?
