Tasrac's avatar
Tasrac
Tutor
Dec 15, 2022
Orbi 850 and Arris SB8200
Wondering if the community can help.  I have an Arris SB8200 modem.  I subscribe to Ultimate 500mb down and 10mb up from Cox.  When doing speed tests, I am only seeing about 90-95mb down on Wi-Fi as fell as a hard wired connection over Cat5e cable.
If I plug direct in to the modem, I am seeing about 200-300mb down (still not close to the 500mb I am paying for).
Also, I noticed the Docsys Upstream light is green indicating 3.0 and should be blue for 3.1.  The downstream light is blue.
Any thoughts on what I  can do with the Orbi configuration to see better speeds?  I have Cox coming to figure out why I am not getting 500mb to the house later today.
  • FURRYe38's avatar
    If your not seeing to spec speed when directly connected to the ISP modem with a PC with out Orbi in the mix, you'll need to contact your ISP and modem Mfr for help and information regarding this. This is on the ISP to ensure all is working well up to the modem.
    Also test with a different PC to compare results.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    • Tasrac's avatar
      Tasrac
      Tutor
      Thanks.  I am having Cox come down later today to troubleshoot).  Before I had my Orbi 850, I used a Linksys router and had no problems with my internal speeds so the wiring is ok (Cat 5e supports up to 1 gb)  As for the wi-fi (5g) the speed tests are coming in at under 100mb.
      • FURRYe38's avatar
        If wired speeds at the modem are low, then the same would be seen at the Orbi wifi as well.
        Once the Modem and issues there are resolve and you finally get to spec speed there, you should see same thru the orbi system as well. The Orbi system can only provide as good as what the modem does.
