Kcram's avatar
Kcram
Orbi 850 main network connection issue
I can see both the main and guest ssid when I tried to search for wifi connection.
when I tried to connect to the main network, it connects for 1 to 2 seconds and the drops out.
connection to guest network is working.
this issue happens almost once a month and the only solution that works for me is to do a factory reset everytime.
just wanted to check if anyone has similar issue and how do they solve it?
  • CrimpOn's avatar
    CrimpOn
    Kcram wrote:
    and the drops out
    Please describe this in more detail.  i.e. "what happens?"
    • The WiFi device displays an error message?
    • Applications on the WiFi device fail to work correctly?
    • It happens to every device connected to the system with WiFi?
    • Kcram's avatar
      Kcram
      basically all devices connected to the main ssid, lost it’s connection. It dropped. When I tried to reconnect, it will show the wifi signal for a few seconds and then disconnects. This happens to all devices that were connected to the main network. Somehow the guest network is not affected.
      the only way that I resolve the issue is by doing a factory reset. Unplugging both the router and satellite for 15 min doesnt work
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    What wireless devices are you connecting to the system? Brand and model# please
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    How many RBS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite â€Śâ€Śđź›°
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
    • Kcram's avatar
      Kcram
      Firmware is 7.2.7.15
      My current set up is: NBN - TPLink Archer router - Orbi 850.
      The TPLink has not connection issues.
      There are about 70 Devices connected to the Orbi Router. A mixture of IOTs(On separate SSID), a couple of Apple and android devices.
      only 1 RBS
      house is 2 storey with a total of about 3000 sq foot
      these are already disbled
      i dont think it has to do with the channel.. Im thinking more about the mac address that you’ve mentioned.
      All devices that connects to the main network lost connection. Or cannot connect. All devices using the guest SSID (different subnet) works fine
      I think when the mac address change it somehow creates a conflict causing the router to reject connections to the main network.
      • FURRYe38's avatar
        See what happens if you disable Mac Address randomizers on those devices that have this feature.
