Sadwkh's avatar
Sadwkh
Orbi 852 optimal settings
Could anyone help me with optimal settings for the orbi 852? I’ve seen the article below but not sure if this applies to the newer models
Thanks so much
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
  • 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
    Set 20/40Mhz Coexistence to 40Mhz only.
    I like to use manual channels 1 and 40.
  • plemans's avatar
    Optimal settings, optimal placement is what I'd look at more.
    The orbi's do a pretty good job for performance. In my experience its more about trying different placements of the router/satellites to optimize coverage than it is about changing settings. I've found trying different locations can surprisingly have quite difference results due to objects in the walls, interference, distance, etc. So try multiple locations for a couple days. When I first got a mesh system, I moved them around once a week for quite a while just trying different configurations.
    Yes it can help to make sure the wifi channels aren't on ones that have interference but that's pretty simple.
    • FURRYe38's avatar
      • Sadwkh's avatar
        Sadwkh
        Thanks very much I have an old period property with thick brick walls. Router in centre ground floor. Satellite far corner of house at least 30 ft away . I keep reading how internet speeds are maintained through out one’s property with the orbi but am not seeing this. Maybe I need some more satellites but trying to avoid extra expenditure.
        Furthermore my lg tv which is not very far away from the router sometimes just loses it’s internet connection, very frustrating
        Many thanks
