Sasquatch3
Oct 11, 2022Aspirant
Orbi 960 Wired Backhaul Question
Quick question about wired backhaul. My current internet service is 1GB ATT fiber, and I go from the ATT gateway (bridge mode) > Orbi (Router Mode) > Network Switch > Satellites. This setup wor...
Sasquatch3
Thanks, but I'm trying to figure out a way to go direct from the gateway to the main orbi unit and 2 satellites as I believe that would allow me to get the most out of the 5GB fiber connection. If I go from the main orbi unit to the two satellites then I might as well just get the 2 GB fiber connection.
Oct 11, 2022Guru - Experienced User
The RBS have to be connected to the RBR even if wired. They won't sync right if connected to the ISP modem.
The limitation will be 2.5Gb on the one LAN port on the RBR. So if you feed the RBR 5GB on it's 10Gb WAN port. The max output you can do from the RBR to the RBS is 2.5Gb. Having the one 2.5Gb LAN port and two RBS, you can output this if you put in a 2.5Gb LAN switch in between the RBR and RBS, then both will connect at 2.5Gb max rate. You'll not see 5Gb ever between the RBS and RBR over LAN.
Honestly you won't see 5Gb over wireless as well. Max rate is 4800Mbps I believe on 6Ghz. The wireless backhaul is limited to 2400Mpbs on 5Ghz. In all my experiences with NG devices I have, I've never seen 4800 once to date on any device. I've come close to 4000Mpbs however that's in close range between two 4x4 or higher supporting MIMO devices. Even with my RAXE500 on 6Ghz with my 9 series, at a normal fair distance, at most I see is 3200Mpbs. From what I'm told to get anything at 4800Mpbs needs near perfect conditions and in variable household conditions, not really viable at a normal daily user base. I wish router mfrs would stop marketing 4800Mpbs.
- HaroldCarlJan 12, 2023Tutor
I thought I would ask what your results are regarding the download and upload speeds you have been able to acheive on downloads with a 2 Gbps or 5 Gbps WAN connection? Additionally, I am also interested whether you performed these quick tests with Netgear Armor turned on as well as off?
- plemansJan 12, 2023Guru - Experienced User
My service is only 1.4gig and it maxes it out. I don't have armor enabled and already used the trial as part of a prior testing so I can't enable it.
- Sasquatch3Jan 12, 2023AspirantOn a 2GB ATT fiber connections, I get ~2.35 up and ~2.35 down using the orbi app Speedtest tool
I really appreciate it, as I didn't know how it would handle anything over a 1 Gbps connection. I also use ATT fiber on their 1 Gbps service. Do you use Netgear Armour on your 960? Do you recall if it was turned on when you ran your speed test?
This is more of a question to the group. I wondered if anyone had done similar speedtests with the ATT fiber 5 Gbps connection using the 960?
