Sasquatch3
Oct 11, 2022Aspirant
Orbi 960 Wired Backhaul Question
Quick question about wired backhaul. My current internet service is 1GB ATT fiber, and I go from the ATT gateway (bridge mode) > Orbi (Router Mode) > Network Switch > Satellites. This setup wor...
mrdata71
Jan 15, 2023Initiate
I do not have the Armor enabled. I honestly did not see an issue getting 2.5GB with it turned on.
I am still waiting on my new components to see if we can get the full 5GB.
Once I have completed my testing, I will let you know the entire setup.
I do know that you need USB 3.2 Gen 2 so you have no limitations from it.
I have been reading that if you do not have a 10Gbps USB adapter and corresponding port on the PC, you will not get the entire 5GB.
Stay Tuned!
HaroldCarl
Jan 17, 2023Tutor
I appreciate everyone's response. For the sake of price concerns and the current technology limitations (i.e. 2.5 GbE port instead of 10 GbE to satellites/lacking SFP+ port for other wired components, and processor regarding threat protection throughput) I will have to remain in wait and see mode. For the time being the best path seems to be to go with the RBKE9 series. Perhaps this is something that could be addressed in a more advanced Orbi Pro model upgrade which seems now to be overdue? With the advent of CAT6A several years ago, I don't think this would be much of a stretch or ask, but time will tell. Perhaps they could even offer a discounted upgrade path to a more advanced unit, for early adopters who obtain the RBKE963 or RBKE964?
All in all, I agree with the other who have posted that on the wired WAN, that at this point, there is really no more discussion regarding upgrading beyond 2.5 GB. As far as the LAN goes, and depending upon your needs/wants sure you could go with a Multi-Gig setup managed setup as you see fit.
I will continue to listen to the thread for new updates and test information with a speed and security focus.
Best Regards
