Retired_Member
Dec 18, 2019Orbi AX AP mode
Hi,
I’ve set my Orbi RBK852 system in AP mode and now video streaming works fine; however all the devices appear to be connected to the main router, despite the satellite is fully working and connected to the router.
Is it possible that the app displays them as all connected to the router even if they’re connected to the satellite or are they actually avoiding the Satellite?
What does the app say for devices connected to the SAT? Nothing or some?
What version of app are you using?
Mine posts devcies that are connected to my SAT. I don't see the same on the router.
- Retired_MemberIt appears as all of them are connected to the router. The sat list is empty
What is the distance between the RBR and RBS? 30 feet is beginning distance.
What happens when you turn down the RBR power on each radio. Say 50% to start. Under Advanced Tab/Advanced Settings/Wireless Settings
