kjguli's avatar
kjguli
Orbi AX Mesh
Firmware Version
V3.2.16.6_1.4.4
I have had my Orbi RBR750 with 2 satellites for a few weeks and in general am very happy.  It has covered the dead spots I used to have. However, I regurlarly have issues where my computer or phone is not connected to the fastest or strongest source.
Example 1:  my desktop computer (does not move) will sometimes connect to the satellite that is 15 feet away (strongest signal) and sometimes the Router that is two rooms and one floor away (good, but lesser signal).
Example 2: my laptop, that sets next to the desktop most of the time will connect to a 2.4G signal (10Mbps) and the desktop will be connected to a 5G signal (140Mbps). Other times the Laptop will connect to the closest 5G signal and run 240Mbps.
1. Why does one signal get used over another?
2. Is there anything I can do to force a particular signal to be used?
Thanks.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    • kjguli's avatar
      kjguli
      Service Provider: Suddenlink
      Modem: ubee UBC 1322
      Satellite 1: 2 rooms and one floor between, ~40 ft from router
      Salellite 2: 2 rooms and 2 floors between, ~30 feet from router
      ~ 40 feet between satellites.
      Satellites positioned using Net Analyzer and Orbi App to get signal in dead areas.
      fyi - walls are plaster
      Channel selection is set to Auto.
      5G band has always come been on Channel 48 and appears to be only WiFi on it.
      2.4G band varies. I have seen channels 1, 4, 6 and 11. It is usually a different channel than the neighbors.
      On one computer setting next to each other the 5G signal tends to be a few points stronger than 2.4G. The second computer is the opposite. I have also noticed the 2.4G strength relative to the 5G increases when the weather is cloudy and humid, and rainy,too.
      I have a few devices in the house that only run on 2.4G.  Will turning down the power output effect them? Can I turn down only the 2.4? is the power output managed for all device as a whole, or vary by device (router/satellites)?
  • Having had similar issues, I'd advise opening a stumbler on the device and seeing, over a 60 second period, the signal strengths in your locations. Apple devices in particular are extremely sticky to access points so if one of the satellites comes up before the other and has a strong and robust 2.4 signal you might just stick there.
    I solved by: 1/being very careful and particular about bringing the satellites up in the order I wanted them in. 2/reducing the power of the 2.4 band -- you can experiment with 25% or 50% -- to change the shape of the wifi coverage cells.
    But first sniff your signals. You may be surprised how strong they are from distant places - and it may be in fact that you don't "need" two satellites. If, like me, you want three access points to get strong signals in a particular room then you have to be creative about shaping the cells and the power
      • Dd852's avatar
        Dd852
        Luminary
        You can affect the shape by changing the position of the router/satellite - high up sends signals further, straight on tends to be stronger than side etc. Sometimes just a 90 or even 45 degree turn can make a huge difference in what picks up what.
        I only know Apple stuff - The best info I know is here https://support.apple.com/en-us/HT206207
        The TL/DR is
        "Consider this threshold in view of the signal overlap between your wireless cells. macOS maintains a connection until the -75 dBm threshold, but 5 GHz cells are designed with a -67 dBm overlap. Those clients will remain connected to the current BSSID longer than you expect.
        Also consider how the cell overlap is measured. The antennas on computers vary from model to model, and they see different cell boundaries than expected. It's always best to use the target device when you measure cell overlap.
        Selection criteria for band, network, and roam candidates
        macOS always defaults to the 5 GHz band over the 2.4 GHz band. This happens as long as the RSSI for a 5 GHz network is -68 dBm or better."
        Other devices by other manufacturers will be different but they'll all have rules of some sort.
