tg88's avatar
tg88
Orbi AX4200 RBK753 - Wifi always connect to main router and not Satellite
Hi
I just bought the  Netgear Orbi AX4200 with 1 router and 2 satellites.
Using the Orbi app, the Network Map says 2x Satellites connected and online. However, I noticed all my wifi devices
seem to connect to the main router instead of the Satellite that is nearest?
Do I need to press the sync button eventhough the orbi app says 2x Satellite located?
I tried this sync option as well but no luck
Is there something i missed from the setup?
Hardware Version: RBR750
Firmware Version: v3.2.18.1_1.4.14
Thanks in advance
  • Problem solved.
    I just hope this is not a used product sold to me from the shop.
    From the browser ORBI settings (attached devices), I noticed something odd.
    My default router IP address is 192.168.1.1
    The addresses I am seeing from the UI as followed.
    Satellite 1 IP address - 192.168.1.5
    Satellite 2 IP address - 192.168.0.43 <----- different subnet!
    How did this device end up with different subnet? is this a glitch?
    To solve this problem, i have to factory reset with a pin and now I am getting the
    correct subnet IP 192.168.1.7 from DHCP
