Datwyl01's avatar
Datwyl01
ORBI AX4200 to ISP Fiber optic modem or router
I have fiber running into my home and am using the ISP FO modem (Alcatel-Lucent) connected to the ISP provided modem (ZYXEL XMG3512). My TV service also runs through this modem (via a ZYXEL HLA3000).
I recently installed the ORBI AX4200 and connected it to the modem as instructed. In the process, I decided to organize my network closet and damaged the FO cable to the modem. The ISP tech came and repaired the FO but rerouted the ORBI through the ISP router. The tech said not to connect the ORBI to the modem because it will mess things up - he didn’t elaborate. He also said the ISP router is required since everything is running through it - including my HD TV and internet.
Any thoughts or concerns? Should I go ahead and connect the ORBI back to the modem or leave it connected to the ISP router? Does it matter?
Not really having any issues connected to the router as far as I can tell, but am I losing any benefits with the current setup?
Thanks in advance.
  • I have reposted this 3x now with zero response from the community. Does ANYONE have any idea about this issue?
    • michaelkenward's avatar
      michaelkenward
      It helps to post in the right place. You won't find many Orbi users here.
      You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
      Many questions apply to different types of device, so there may be useful responses here, but Orbi systems are not like standard routers, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
      Orbi - NETGEAR Communities
      I will ask the Netgear moderator to move your message.
      In the meantime you could visit the support pages:
      Support | NETGEAR
      Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
      You may have done this already. I can't tell from your message.
      I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • FURRYe38's avatar
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    SInce your ISP said the ISP router is required, I would try option #2 or #3...
    • Datwyl01's avatar
      Datwyl01
      Slightly confused. I understand the 3 options you suggested. I’m confused about your first sentence, “ Your ISP Modem already has a built in router and wifi.”
      The ISP supplied 3 pieces of equipment: (1) The fiber optic modem (Alcatel-Lucent 3FE51880AK I-240G-C ); (2) the ISP provided router (ZYXEL XMG3512). I mistakenly called this a modem in the original post. And (3) ZYXEL HLA3000 for the TV service connected to the router.
      Are we still talking Double NAT?
      I plan to call the ISP tech support to verify the info told to me by the service tech
      Anything else I should ask?
      • FURRYe38's avatar
        Yes if the tech connected the RBR to the ISP provided router (ZYXEL XMG3512), this is double NAT. One of the options mentioned will help with this.
