SueBray's avatar
SueBray
Orbi AX4200 Tri-Band Mesh WiFi 6 System compatible with which Netgear Outdoor extender?
We have a home that has the Orbi AX4200 Tri-Band Mesh WiFi 6 System installed. We need an outdoor wireless extender that can work with that system. And, we cannot run any cabling, except to plug in the power for the outdoor device. What extender would be compatible with the Orbi AX4200 Tri-Band Mesh WiFi 6 System? On an older Orbi system we used the AC3000 Mesh WiFi Range Extender (RBS50Y) and it worked great. Now that we've upgraded we're unsure of what to use. TIA -- Sue
  • FURRYe38's avatar
    If you can get the extender mode FW loaded on the RBS50Y, it could work with the Orbi AX system. Otherwise, there isn't any new AX NG out door extenders available. Might check out some 3rd party Mfrs to see if they have any outdoor rated extenders.
