redleader-NET
Mar 04, 2021Aspirant
Orbi AX4200 w/ Xfinity (Comcast) gateway
Hello there,
So my house currently uses an Xfinity gateway (using both modem and router features). However, tons of slow/dead spots in the house so I plan on getting the Orbi AX4200 mesh system. I understand that I need to set the gateway to bridge mode so that the gateway stops serving as a wifi router, handing over those duties to the Orbi. The only service/equipment that I also have from Comcast is their security camera system. However, the cameras are wired directly to a video device that is then directly wired to the gateway. So since the cameras are not wifi based, is it safe to set the gateway to bridge mode?
redleader-NET wrote:Hello there,
You should be able to connect the video device to the Orbi instead of the Comcast gateway. Essentially, your Orbi replaces the gateway so reconnect everything to the Orbi base or satellite. The only thing wired to the gateway will be the Orbi base.
Please visit and post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
Any progress on this?
- redleader-NETAspirant
Great, thanks for the reply. We'll try this out. I had read in other threads that if you have other Comcast/Xfinity Devices in the house that use the Gateway, you wouldn't be able to turn off its wifi completely, but I suppose a hardwired video device (i.e., not on wifi) should be OK.
Let us know how it goes...
