ahmedoozziee
Sep 10, 2025Aspirant
Orbi AX4200 WiFi 6 High-Performance Router for Ooredoo (RBR750 (Ooredoo))
i've bought a used Orbi AX4200 WiFi 6 High-Performance Router for Ooredoo (RBR750 (Ooredoo)), I want to flash it with stock firmware.
Netgear firmware for the RBR750 and satellites is here:
https://kb.netgear.com/000066598
The recommended procedure is to manually install firmware on the satellites first, and then install on the router last.
- ahmedoozzieeAspirant
ThanksCrimpOn for your response, This will unlock the router ?
If this was a orbi system provided by a 3rd party or ISP service, you'll need to contact them to check and see if NG stock FW can be loaded on it. Loading NG stock FW may not work if this system was not a retail unit.
